Case Name Fire caused by explosion of p-nitrophenol sodium salt due to friction during transfer with a conveyor
Date August 25, 1979
Place Fukuyama, Hiroshima, Japan
Overview On August 25th, 1979, dried p-nitrophenol sodium salt ignited during transfer into a warehouse in Fukuyama, Hiroshima. The warehouse exploded and was totally destroyed by fire. The cause was considered to be overheating due to friction around the conveyor.
Incident Raw material for pesticide production ignited during being transferred into a warehouse due to friction, and the warehouse exploded and burned completely.
Individual Process Transfer
Substance p-nitrophenol sodium salt, Fig3
Sequence Dried p-nitrophenol sodium salt was transferred into a warehouse by a screw conveyor. White fumes were seen around the conveyor, and the warehouse exploded and burned completely.
Cause Dried p-nitrophenol sodium salt was ignited by friction during transfer with a screw conveyor.
Knowledge Comment 1. Friction control of a screw conveyor.
2. Is it appropriate to use a conveyor for transferring combustible materials? Use of pneumatic conveying with inert nitrogen gas might be an appropriate choice for transferring powder and pellets.
Background The operation was routine work and it is not clear why friction was generated. Inadequate maintenance of a conveyor such as over-tightening or dropping foreign materials into a key place of the conveyor was suspected.
Reason for Adding to DB Example of explosion and fire caused due to frictional heat during transfer with a conveyor
Primary Scenario Carelessness, Insufficient Precaution, Carelessness to Handling of Impact Danger Material, Poor Value Perception, Poor Safety Awareness, Insufficient Recognition of Risk, Usage, Maintenance/Repair, Friction Generated at Conveyor, Bad Event, Mechanical Event, Friction, Secondary Damage, External Damage, Explosion, Loss to Organization, Economic Loss, Failure of Buildings
Sources Masamitsu Tamura. Masahide Wakakura. Explosion of p-nitrophenol sodium salt. Reaction danger - Accident case and analysis - p. 89(1995)
Physical Damage 40 square meters of the factory burned, 61 square meters ware house completely burned
