Steam explosion caused due to water leakage at an electric furnace |
June 6, 1992 |
Takamatsu, Kagawa, Japan |
Ironworks |
Metal scraps were charged into the electric furnace and melted. The water frame mounted to the electric furnace wall was damaged, water leaked, and a steam explosion occurred. |
A steam explosion occurred during melting work of metal scraps in an electric furnace. A water frame was partially melted and a hole was generated. Then, water leaked out through the hole and caused a steam explosion. A hot blast and molten steel were scattered, and ignited the combustibles nearby. Two operators were seriously injured and four were slightly injured. Water frame: a steel jacket for cooling water. |
Other |
Iron, Fig2 |
Explosion, Fire |
Metal scraps were charged into the electric furnace, and then melting finished. A container was set up for taking out the molten steel. A water frame was partially melted. A hole was generated and water leaked through it. Leaked water went between molten steel and slag, and it caused a steam explosion. A hot blast occurred and the molten steel was scattered. Combustibles nearby were ignited. |
Partial damage to the water frame. |
The injured were taken to the hospital. The fire was extinguished by powder extinguishers. |
The causes of water frame damage should be eliminated. Water leakage should be detected early. |
Molten metals are always at a high temperature. Design and management of the area equipped with water supply facilities should be considered based on this fact. |
An automatic oxygen supply pipe came close to the water frame, and a steel plate of the water frame was shaved. It might be a design error or insufficient inspections. |
Example of steam explosion caused due to a particular reason |
Poor Value Perception, Poor Safety Awareness, Inadequate Risk Recognition, Carelessness, Insufficient Understanding, Insufficient Recognition of Risk, Planning and Design, Poor Planning, Poor Design, Usage, Operation/Use, Operation of the Machine, Failure, Large-Scale Damage, Scarfing, Secondary Damage, External Damage, Explosion, Bodily Harm, Injury, 6person injured, Loss to Organization, Economic Loss, Direct Monetary Damage 10 million yen
Outline of significant accident in 1992, Safety year book, p.222
Fire and disaster Management Agency, Major Accident Case - Steam explosion in electric furnace, Accident cases of dangerous materials, pp.31,422-423
6 |
An electric furnace was damaged. Buildings around the electric furnace and materials in the buildings were damaged and burned. Molten steel was damaged. |
¥ 11 million. (Accident cases of dangerous materials) |
| Notes |
Steam explosion |
