Explosion of 5- chloro -1,2,3- thiadiazole (5CT) |
May 14, 1980 |
Urawa, Saitama, Japan |
Pharmaceutical factory |
An explosion occurred at a company during manufacturing a new material 5- chloro -1,2,3- thiadiazole (5CT) at a request. The cause of the accident might be that the both a manufacturing consigner and a manufacturing contractor had little knowledge of the potential hazard of 5CT. |
In trial manufacture of 5CT, an explosion and fire occurred during packaging work into a transfer container after vacuum distillation. Harmful gas was generated, and adjacent residents were evacuated. |
Filling and subdivision |
5- chloro -1,2,3- thiadiazole(5CT), Fig3 |
Explosion, fire |
5CT was distilled under reduced pressure at 50 mmHg. The first fraction was discarded in the morning and the main fraction was collected in a 500 L receiver drum in the afternoon. Afterwards, the receiver drum was heated (the freezing point of 5CT is 20-25 °C) again after water-cooling to about 40 °C with steam. The explosion occurred during packaging work while a chemical hose was connected to a flash valve and 5CT was filled to chemical drum. |
not clear |
Countermeasures were not taken because of the cause is unknown. |
For a newly handled material, an assessment of potential hazards is necessary. |
The potential hazard of 5CT |
5CT easily ignites in a container due to friction or impact. It easily explodes when ignites, and reacts intensely to heat. The explosive power is about 80% that of TNT. The facts above were proven in the investigation after the accident. |
In those days, 5CT was a newly handled material in Japan. However, there were records of an explosion at BASF Co. in Germany. Besides, there is an article in a magazine that says the major company that requested the manufacture of 5CT to this company might have known the explosion hazard of 5CT, because another explosion had occurred at a different 5CT manufacturing company, which was a contractor of the major company a year before, and moral responsibility of the major company became an issue. |
Example of explosion of material with unknown hazards |
Organizational Problems, Inflexible Management Structure, Acceptance of Unfair Requirement, Insufficient Analysis or Research, Insufficient Prior Research, No Evaluation about Potential Hazard, Non-Regular Action, Change, Execution of New Experiment, Secondary Damage, External Damage, Explosion, Bodily Harm, Death, 2 pereson died, Bodily Harm, Injury, 12 person injured, Damage to Society, Social Systems Failure, 600 person emergency refuge, 400 houses damaged, Loss to Organization, Economic Loss
Fire and Disaster Management Agency, Examples of accidents manufacturers of dangerous objects, 1981, pp.222-223
Fire-Defense Headquarters of the Urawa City. K chemical and synthetic industry fire caused by explosion - outline, Modern fire fighting, No.212, pp.113-116(1980)
Masamitsu Tamura, Mitsuru Arai, Yoshiaki Akutsu, 5CT explosion, High - energy material and safety, pp.58-59(1999).
17 |
36 buildings of factories, etc. collapsed or partially collapsed. 397 adjacent residential units and windows were damaged. |
| Consequences |
Hydrogen chloride gas was generated with an offensive odor in the vicinity and things fell down from shelves in adjacent residential units. 19:13, on May 14th, 1980: An evacuation order was announced to adjacent residents because of the hazard of explosion and/or pollution by harmful gas, and about 610 persons were evacuated to three locations, The order was canceled at 08:00, on May 15th, |
