In the construction field, a person was run over by the drag shovel during photographing |
April 10, 1997 |
Obihiro,Hokkaido |
The construction field of sewage treatment facility |
In this accident, the victim was run over by the right side crawler track of the reversing drag shovel while he was preparing to take a photograph for recording the work situation. |
run over by the reversing drag shovel |
On that day the accident happened, back-filling and surface compaction work for west-side and north-side of sewage treatment facility, which began on that morning, were almost finished. Then at about 2:30 p.m., deciding to take the documentary photography, the victim started to prepare to do so in the place where drag shovel, which was in stopped standby state for leveling out the plot of land work, was at the back of him.Then the driver of the dump truck, which had carried earth and sands, intended to unload those. But as the stopped drag shovel lay in the way, he reversed the drag shovel about one meter and caught the victim, who was preparing photo shoots, under the crawler track. |
* The driver operated the drag shovel without any signal or guide of conductor. * The driver did not realize the fact that there was the victim behind the drag shovel. * Any measures to place off-limits control against the contact hazard in the running range of the drag shovel had not been taken. |
* You should forbid entrance to the operation range of the car type construction equipment and express clearly the prohibition zone with signboards, barriers, ropes, etc. * If it is necessary to make a worker enter the operation range or running range of the car type construction equipment and carry out the work, you should station certain conductor and make the driver of the equipment run following the signal from the conductor. |
In the case of the work using the car type construction equipment, you should make work plan suitable for the job site situation in advance, regarding types and ability, operation routes, and methods of the work, setting of the entrance prohibition zone and disposition of the conductor, etc. of the equipment, and carry out the work according to the plan. |
You should prohibit workers to enter into the operation range of the car type construction equipment, in general. |
Since this is a typical case of the accident with the car type construction equipment. |
Poor Value Perception, Poor Safety Awareness, Poor Value Perception, Poor Safety Awareness, Carelessness, Insufficient Precaution, Usage, Operation/Use, Bodily Harm, Death
http://www.jaish.gr.jp ( Japan Advanced Information Center of Safety and Health )
Not clear |
Economic Loss |
Not clear |
Consequences |
The labor accident with the car type construction equipment occupies a large proportion of, especially fatal accident, of the construction industry. So, taking strong prevention measures has been called for. |
Fig2.Position where seven people work
KITAYAMA, Hiroyuki (Japan Crane Association)
