Case Name A carpenter falls during fabrication of the plaster board from the entrance wellhole.
Date July 20, 2000
Location Construction field of new 2-floor wooden house.
Overview A carpenter was cutting palster boards piled on the hole on the 2nd floor of new wooden house. He stepped back without care then missed his step, and he fell down to concrete ground 3m below from the entrance wellhole.
Incident Around 14:00, 7/20,in the construction field of new wooden house(2-floors), a carpenter missed his step and fell down to concrete ground 3m below from the entrance wellhole, and got wounded of conpulsory rest for 2 months
Sequence In the morning of the accident day, Directions of the share and arrangement of the work,and its contents were done by the president of the subcontractor on the telephone.
The supervisor of the contractor and the president of subcontractor directed the carpenter to fix the handrail on the wellhole, but they did not confirm that and left there.
The carpenter started to cut the plaster boards piled on the hole on the 2nd floor.
Around 14:30 , he stepped back without care, then missed his step and fell down to concrete ground of the 1st floor.
Cause The carpenter fell because he turned his back to the wellhole and worked and stepped back without care.
In the wellhole, the handrail to prevent fall was not installed.
Response In the entrance wellhole , the work must be carried out, after the handrail for the fall prevention is certainly installed.
Countermeasures In the wellhole, the installation of the handrail for the fall prevention must be done thoroughly.
The supervisor of the contractor and the president of subcontractor must check if the direction they make is surely executed.
By the education of priority of safety, and the execution of danger prediction, enhance the intention of safty .
Knowledge Comment Make texts of the installation basis of handrails on the wellhole, and ,make workers know it thoroughly.
The supervisor of the contractor and the president of subcontractor must check if the direction they make is surely executed. And if they find some disorders, make the improbement on paper and formula, let the persons concerned know them and execute them.
Background The carpenter directed the installation of handrail on the wellhole thought that the handrails would be prevent his work, so he left there as it was.And he was absorbed in the work, he lost the caution of the hole behind him.
The supervisor of the contractor has many place to visit, so he could not stay so long.
The president of the subcontractor was also dependent on the carpenter thoroughly, then he thought the check of the installation of handrails were not his duty.
Sequel A direction was done to all the supervisor of every site that if there is a miss of confirmation of fall-prevention , they should fix immediately.
To check the improvement by the direction, it was made as duty that a photo should be handed in.
Prediction of danger and its direction was followed by the supervisors on patrol .
Incidental Discussion These operational procedure book and safety and health management regulation were not thought to be the duty of the subcontractor. It was thought to be the duty of contractor.
Account of Concerned Parties The carpenter did not has a custom to tighten the jaw strap , and that was not directed,so his helmet went away when he fell.
That work was done by himself only, so he did not joined to the safety meeting before the work.
Reason for Adding to DB To prevent the labor disaster as this.
Primary Scenario Misjudgment, Misjudgment of Situation, Carelessness, Insufficient Precaution, Organizational Problems, Poor Management, Regular Movement, Dangerous Movement, Regular Movement, Dangerous Movement, Production, Hardware Production
Sources Construction industry labor accident prevention association, "the STM course" sheet collection.
Number of Deaths 0
Number of Injuries 1
Consequences The occurrence of labor disasters on the lower house construciton sites causes the distrust of contractor and subcontractor's management duty,and anxieties of the residents and visitors for the danger .
