A crashing accident from the bridge pier in the bridge superstructure work. |
July 2000 |
Kagoshima Prefecture. |
Bridge superstructure work field in the national road motorway. |
Three workers carried out the assembly of the circumference scaffold on the bridge pier for bridge superstructure work. |
When the work had come to the end of the first stage and workers began to take a rest, the victims went the outside of the crash prevention fence on the bridge pier, and fell down from the side wall of the bridge pier. One of them died. |
* Three workers took a rest after they installed the bracket to set stage planks of the bridge pier side, and laid them in such a condition that the two of the three sheets of stage planks were not fixed on the bracket. * The stage plank was longer than the designated length and it was hanging out of the blacket. It was balancing. * The victim climbed over the crash prevention fence during the rest. He fell down with two sheets of stage plank and died. Three workers had constructed the circumference scaffold of the bridge pier. The leader and the subleader had worked outside the crash prevention fence, and the victim had worked inside it. Three workers installed brackets to hold the stage planks of the flank of the bridge pier. They hold the two of the three sheets of stage planks, and they laid out the next work. Agter that, they took a rest at 10 p.m. The brackets were put on without cutting the plank off at the necessary length, and laid it unfixed. The condition of the half of the stage plank was like a balance. * The victim fell with 2 sheets of stage planks from the flank of the bridge pier outside the crash prevention fence when the leader arranged insufficient materials and the subleader intended to pass under the crash prevention fence to go to the rest space. There was no eyewitness. |
* During the rest, the worker went out of the crash prevention fence carelessly and went up to the danger our place. The reason why he went up to the dangerous place is unknown. |
* The subcontract company checked the consistency of the plan of the temporary construction and the actual field. |
* It is necessary to make others know the field circumstances for example, no trespassing, etc. when workers interrupted their work unavoidably in the unsafe situation. * Workers shouldn't enter the dangerous place. |
* The victim was 18 years old and had little experience. * The victim had worked in the construction field for 3 months. |
It is important to realize the danger of entering the dangerous place again. |
Poor Value Perception, Poor Safety Awareness, Carelessness, Insufficient Precaution, Organizational Problems, Poor Management, Non-Regular Action, Inaction, Regular Movement, Dangerous Movement, Bodily Harm, Death, Loss to Organization, Social Loss
None |
MIZOGUCHI, Hiroki (National Institute for Land and Infrastructure Management)
