Case Name Under tension work of the PC girder, the PC steel strand wire projected and it stuck in the left thigh of a worker.
Date October 24, 1997
Place Nagato Town Nagano Prefecture
Location New construction site of bridge with the road improvement work.
Overview During tension work of PC girder (prestressed concrete), one of the wedges which were fixing 12 PC strand wires slipped, the wire projected out from PC steel and it stuck in the left thigh of the worker at the rear of opposite side jack.
Incident Under tension work of the PC girder, the PC steel strand wire projected and it stuck in the left thigh of a worker.
Sequence The tension work ended on the 2 PC cables out of 4 which placed in PC girder, and the third PC cable were being tensed. When tension work to be close to ultimate tensile force, it was found that the stroke of the tension jack wasn't sufficient , the jack couldn't reach fixed tensile force and dlongation quantity because of a failure of set of the tension jack. Therefore, the cable was to be fixed once and re-tension.
When it set a tension jack to re-tension and began to increase the pressure, one of the cuneal which was respectively fixing 12 PC steel strand wire (φ 15.2mm) by the other tension jack, and one of the PC steel strand wire rushed in the opposite side out, and then it stuck in left foot femoral region of the worker at the rear of opposite side jack.
Cause * The fitting of the wedge which fixed the PC steel strand wire in the tension jack was not accurately carried out based on the manual.
* The victim worked in the dangerous position (rear of the tension jack).
Countermeasures Retraining in how to do tension works.
1.The retraining in the operational procedure.
2.Preparation and inspection before the tension.
Knowledge Comment * The observance of the operational procedure.
* During tension work, forbid somebody to enter behind the tension jack.
Background It was an action disregarded the process-manual which came from habits work.
Sequel In this tension work, each operators tended to compete in terms of the speed of the jack set, and they neglected the operation procedure in their hurry.
Account of Concerned Parties The operation procedure was neglected in the operator's hurry since the other tension jack had been set.
Reason for Adding to DB There are many similarity accidents!!
It is the dangerous work be capable doing of fatal accident!!
Primary Scenario Ignorance of Procedure, Disregard of Procedure, Poor Value Perception, Poor Safety Awareness, Regular Operation, Nonobservance of Procedure, Bodily Harm, Injury
Sources "The Prestressed Concrete Building Contractors Soc." The Safe Environment Bureau Association.
Number of Deaths 0
Number of Injuries 1
Physical Damage Indefinite
Financial Cost Indefinite
Economic Loss Indefinite
Author YAMAZAKI, Eiji (DPS Bridge Works Co., Ltd.)
